Kann ich alle Homematic (ohne IP) Geräte via Cloudmatic und Conrad Connect nutzen?
Hallo zusammen!
Meine Homematic Installation umfasst 60 Geräte.
ConradConnect-Cloudmatic zeigt nur 36 an.
Wenn ich eine 3rd Party App (PocketControl HM) verwende sind alle 60 Geräte sichtbar.
Hat jemand ähnliche Erfahrungen und vielleicht eine Idee woran es liegen könnte?
Merci!
Vl weil nicht alle Geräte kompatibel sind? Hier ist die Liste die Conrad Connect im Help Center zeigt
HM-Cen-O-TW-x-x-2 Central Control Unit CCU2
HM-CC-RT-DN Wireless Radiator Thermostat
HM-TC-IT-WM-W-EU Wireless Room Thermostat, surface mount
HM-WDS10-TH-O Wireless Temperature/Humidity Sensor, outdoor
HM-WDS40-TH-I-2 Wireless Temperature/Humidity Sensor, indoor
HM-WDS30-T-O Wireless Temperature Sensor, outdoor
HM-Sec-RHS Wireless Window Rotary Handle Sensor
HM-Sec-SC-2 Wireless Shutter Contact
HM-Sec-SCo Wireless Door/Window Sensor, optical
HM-PB-4Dis-WM-2
Flat wireless push-button with colour graphic display
HM-SwI-3-FM Wireless Switch Interface 3 channels, flush-mount
HM-LC-Dim1PWM-CV
Wireless Dimming Actuator 1-channel, PWM LED, ceiling-void mount
HM-SCI-3-FM
Wireless Shutter Contact Interface 3-channel, flush-mount
HM-LC-Dim1T-FM
Wireless Dimming Actuator 1-channel, trailing edge, flush-mount
HM-PBI-4-FM
Wireless Push-Button Interface 4-channel, flush-mount
HM-LC-Dim1T-CV
Wireless Dimming Actuator 1-channel, trailing edge, ceiling-void mount
HM-PB-2-WM55-2 Wireless Push-Button 2 channels, surface-mount
HM-LC-Dim1L-CV
Wireless Dimming Actuator 1-channel, leading edge, ceiling void mount
HM-RC-2-PBU-FM
Wireless Remote Control 2-channel for brand switch systems, flush-mount
HM-LC-Dim2T-SM
Wireless Dimming Actuator 2-channel, trailing edge, surface-mount
HM-LC-Dim2L-SM
Wireless Dimming Actuator 2-channel, leading edge, surface-mount
HM-LC-Sw1-SM
Wireless Switch Actuator 1-channel, surface-mount
HM-LC-Sw4-SM
Wireless Switch Actuator 4-channel, surface-mount
HM-LC-Sw4-DR
Wireless Switch Actuator 4-channel, DIN-rail mount
HM-ES-PMSw1-Pl-DN-R1
Wireless Switch Actuator 1-channel with power metering, plug adapter type F
HM-PB-6-WM55 Wireless Push-Button 6 channels, surface-mount
HM-LC-Sw1-FM Wireless Switch Actuator 1-channel, flush-mount
HM-LC-Dim1TPBU-FM
Wireless Dimming Actuator 1-channel for brand switch systems, trailing edge, flush-mount
HM-LC-Sw1PBU-FM
Wireless Switch Actuator 1-channel for brand switch systems, flush-mount
HM-LC-Sw2-FM Wireless Switch Actuator 2-channel, flush-mount
HM-LC-Sw4-WM Wireless Switch Actuator 4-channel, wall-mount
HM-Dis-EP-WM55
Wireless Status Display with push-button for 55 mm frames
HM-LC-Sw1-DR
Wireless Switch Actuator 1-channel, DIN rail mount
HM-LC-Dim1T-DR
Wireless Dimming Actuator 1-channel, DIN rail mount
HM-LC-Sw1-Pl-DN-R1
Wireless Switch Actuator 1-channel, plug adapter type F
HM-LC-Bl1-SM
Wireless Shutter Actuator 1-channel, surface-mount
HM-LC-Bl1-FM Wireless Shutter Actuator 1-channel, flush-mount
HM-LC-Bl1PBU-FM
Wireless Shutter Actuator 1-channel for brand switch systems, flush-mount
HM-Sec-SD-2 Wireless Smoke Alarm
HM-Sen-MDIR-O-2 Wireless Motion Detector, outdoor
HM-OU-LED16 Wireless Status Monitor LED16
HM-Sec-Sir-WM Wireless Siren with signal light
HM-Sen-EP Wireless Sensor for Electrical Pulses
HM-Sec-WDS-2 Wireless Water Detection Sensor
HM-Sec-SFA-SM Wireless Siren/Flash Actuator
HM-Sec-MDIR-2 Wireless Motion Detector, indoor
HM-RC-Sec4-3 Remote Control 4 buttons, alarm
HM-OU-CFM-TW Wireless Combination Signalling Device MP3
HM-Sec-TiS Wireless Tilt Sensor
HM-RC-Key4-3 Remote Control 4 buttons KeyMatic
HM-Sec-Key-S
Wireless Door Lock Actuator KeyMatic, silver with remote control
HM-Sec-Key
Wireless Door Lock Actuator KeyMatic, white with remote control
HM-Sec-Win Wireless Window Drive WinMatic
HM-RC-4-3 Remote Control, 4 buttons
HM-RC-12-W Remote Control 12 buttons, white
HM-RC-12-B Remote Control 12 buttons, black
HM-RC-19 Remote Control 19 buttons, white
HM-RC-19-B Remote Control 19 buttons
HM-RC-8 Remote Control 8 buttons
HM-Sen-RD-O Wireless Rain Sensor
HM-WDS100-C6-O-2 Wireless Weather Data Sensor
HMW-LC-Sw2-DR
Wired RS485 Switch Actuator 2-channel, DIN rail mount
HMW-Sys-Tm-DR Wired RS485 Bus Terminator, DIN rail mount
HMW-LC-Dim1L-DR
Wired RS485 Dimming Actuator 1-channel, leading edge, DIN rail mount
HMW-LC-Bl1-DR
Wired RS485 Shutter Actuator 1-channel, DIN rail mount
HMW-IO-12-Sw14-DR
Wired RS485 I/O Module with 12 inputs, 14 outputs, DIN rail mount
HMW-IO-12-Sw7-DR
Wired RS485 I/O Module 12-channel in, 7-channel switch actuator, DIN rail mount
HMW-Sen-SC-12-DR
Wired RS485 Shutter Contact 12-channel, DIN rail mount
HM-OU-CF-Pl Wireless door chime with light signal 1-channel
HM-CC-SCD Wireless Carbon Dioxide Sensor
HM-Sec-MDIR-3 Wireless Motion Detector, indoor
HM-LC-Dim1T-Pl-3
Wireless Dimming Actuator 1-channel, leading edge, plug adapter
HM-LC-Dim1L-Pl-3
Wireless Dimming Actuator 1-channel, trailing edge, plug adapter
HM-LC-Sw1-Ba-PCB Wireless Switch Actuator, battery powered
Danke!
Das scheint die Lösung zu sein.
Blöd ist es trotzdem. Beispiele:
Ja, die Dinger sind schon ein paar Jahre alt, aber funktional hat sich da nichts geändert.
Werde mal versuchen einen Service-Request zu öffnen.....
Komischerweise werden bei mir leider beide Steckdosenschalter "Homematic Funk-Schaltaktor HM-ES-PMSw1-Pl" nicht angezeigt... obwohl laut Liste ja kompatibel?
Jemand die Dinger am Laufen via Conrad Connect?
Hallo @adrian_geng, läuft es denn sonst prinzipiell bei dir?
