List of compatible Homematic IP devices
The table below indicates which Homematic IP devices are currently compatible with Conrad Connect. Please note that only Homematic IP systems powered by an Access Point (HmIP-HAP) gateway will be supported. Last updat as of May 20th, 2019.
Product Description/EAN
HmIP-HAP Access point
HmIP-ASIR* Alarm Siren*
HmIP-BBL Blinds Actuator for brand switches
HmIP-BDT Dimming Actuator for brand switches - trailing-edge
HmIP-BRC2 Remote Control for brand switches – 2 channels
HmIP-BROLL Shutter Actuator for brand switches
HmIP-BSM Switch Actuator and Meter for brand switches
HmIP-BSL* Switch Actuator – with signal lamp*
HmIP-BWTH / WTH Wall Thermostat with control wheel, 230 V
HmIP-BWTH24 Wall Thermostat with control wheel, 24V
HMIP-eTRV / TRV Radiator Thermostat
HmIP-eTRV-2 Radiator Thermostat
HmIP-eTRV-2-UK / TRV-UK Radiator Thermostat UK
HmIP-eTRV-B Radiator Thermostat
HmIP-eTRV-C Radiator Thermostat - compact
HmIP-FAL230-C10 / FAL230-C10 Floor Heating Actuator – 10 channels, 230 V
HmIP-FAL230-C6 / FAL230-C6 Floor Heating Actuator – 6 channels, 230 V
HmIP-FAL24-C10 / FAL24-C10 Floor Heating Actuator – 10 channels, 24 V
HmIP-FAL24-C6 / FAL24-C6 Floor Heating Actuator – 6 channels, 24 V
HmIP-FBL Blind Actuator – flush-mount
HmIP-FDT Dimming Actuator flush-mount – trailing edge
HmIP-FROLL Shutter Actuator – flush-mount
HmIP-FSM Switch Actuator and Meter – flush-mount
HmIP-FSM16 Switch Actuator and Meter (16 A) – flush-mount
HmIP-PCBS Switch Circuit Board
HmIP-PCBS-BAT Switch Circuit Board for battery power supply
HmIP-PDT Smart dimmer plug
HmIP-PDT-UK / PDT Smart dimmer plug
HmIP-PS Smart plug
HMIP-PSM Smart plug with power meter
HmIP-PSM-CH Smart plug with power meter
HmIP-PSM-IT Smart plug with power meter
HmIP-PSM-PE Smart plug with power meter
HmIP-PSM-UK Smart plug with power meter
HmIP-RC8* Remote Control - 8 buttons*
HmIP-SMI Motion Detector with Brightness Sensor - inside
HmIP-SMO/SMO-A Motion Detector with Brightness Sensor - outdoor
HmIP-SPI Presence Sensor – indoor
HmIP-SRH Window Handle Sensor
HmIP-STH* Temperature and Humidity Sensor – indoor*
HmIP-STHD* Temperature and Humidity Sensor with Display – indoor*
HmIP-STHO/STHO-A* Temperature and Humidity Sensor – outdoor*
HmIP-SWD Water leakage sensor
HMIP-SWDO Window / Door optical sensor
HmIP-SWDO-I Window / Door optical sensor
HmIP-SWDM Window / Door Contact with magnet
HmIP-SWSD Smoke Alarm with Q label
HMIP-WRC2* Wall-mount Remote Control - 2-button*
HMIP-WRC6* Wall-mount Remote Control - 6-button*
HMIP-WTH / WTH-2 Wall Thermostat
HmIP-SK1 Starter Set Climate Control
HmIP-SK4 Starter Set Smoke Alarm
HmIP-SK5 Starter Set Shading/ Starter Set Shutter Control
HmIP-SK6 Starter Set Light
HmIP-SK7* Starter Set Alarm*
HmIP-SK8* Starter Set Water Alarm*
HmIP-SK9 Starter Set Heating
Information provided without guarantee. Please be aware that the manufacturer might have changed the list of compatible devices since our last update!
  • For an additional information about the Homematic IP integration details please click here.
