Controlling Homematic IP devices with Conrad Connect
Finally the long awaited integration is done. From now on you can monitor and control compatible Homematic IP devices directly through Conrad Connect. Check the real-time status of your devices using the Conrad Connect Dashboard or create Home Automation projects in conjunction with smart devices from more than 50 brands.
Here are a few links to get you started:
1. How to connect Homematic IP with Conrad Connect
2. List of compatible Homematic IP devices
3. Sample projects
Please use our new forum category Homematic IP English for related discussions.
