How to define a project by using the Project Editor?
ConradConnectConradConnect Administrator Posts: 75 admin
In order to define a project you’ll need to select and assign a sensor via the drag-and-drop interface. Online data such as weather information, date and time may also be used as sensors. Next, choose an actuator and assign it to your sensor. Once you’ve done this, save the project. More complex projects may use multiple sensors and actuators involving a set of logic gates. Simple projects may be defined at any time using the dashboard instead.
