How do I change the time on my Fitbit tracker?
The time displayed on your tracker should match the time on the phone or computer you use to sync your tracker.
  • If you have a Fitbit Blaze or Fitbit Charge HR:
  • Blaze—If you shut down your tracker or the battery drains completely, the time will be wrong until you sync. Below please find step-by-step instructions:
  • From the Fitbit app dashboard, tap the Account icon.
  • Tap your tracker tile.
  • Tap Sync Now.
  • Charge HR—Make sure your tracker is updated. The firmware version installed on your tracker should be 18.122. For instructions on where to find the version number, please refer to the Fitbit Help Center.
  • If the time is wrong, make sure the time zone setting is correct. This can be done via mobile or desktop app or via Fitbit Dashboard.
  • Fitbit App for IOS and Android
  • Tap Advanced Settings.
  • Under Time Zone, turn off the Set Automatically option.
  • Tap Time Zone and select the correct time zone.
  • Sync your tracker.
  • Fitbit App for Windows 10
  • From the Fitbit app dashboard, tap or click the Account icon.
  • Tap or click Advanced Settings.
  • Tap or click Time Zone.
  • Turn off the Auto option and select the correct time zone.
  • Fitbit.com Dashboard
  • Log into your fitbit.com dashboard and click the gear icon.
  • Choose Settings > Personal Info.
  • Under Advanced Settings, find Timezone and choose your time zone. Time zones offset by the half hour are not supported.
    Click Submit and sync your tracker.
