How do I use IFTTT as a sensor?
edited August 2018 in FAQs
In order to use IFTTT as an sensor on Conrad Connect please follow the instructions:
Log in to your IFTTT account
Search for the “Webhooks” and press “Connect”
On “Webhooks” service page go to settings. You will see URL your unique URL. Copy a key after “https://maker.ifttt.com/use/” E.g. If your URL is: https://maker.ifttt.com/use/abc123, you need to copy "abc123".
Once done, log in to your Conrad Connect account and go to “Devices & Services” page.
Search for IFTTT under “Services to connect” and enter the key you’ve copied
Now you have connected your IFTTT account to Conrad Connect. Next, let's learn how to use IFTTT applets as an sensor.
Make a new applet on IFTTT. As “this” select something you want (e.g. Button or Email)
As “that” select "Webhooks"
URL: https://dashboard.conradconnect.de/api/webhook/ifttt?key=abc123 (Where "abc123" is the same key you used to authenticate with)
Method: Post
Content-Type: application/json
Body: {"event":"EVENT_NAME"} Create an"EVENT_NAME" which will be used for IFTTT sensor on Conrad Connect in the "event" field
Now, on Conrad Connect you are able to use IFTTT applet as a sensor.
