These window / door contact sensors work with Conrad Connect
ChristianChristian Administrator, Moderator Posts: 1,206 admin
Door contacts and window contacts (also referered to as opening detection sensors) are key to most security or home automation solutions. We show you which hardware works with Conrad Connect
Brand Make Additional Requirements
Innogy SmartHome Window / Door Contact SmartHome Gateway
Homematic IP Window / Door Contact HMIP-SWDO Homematic IP FAccess Point
Window / Door Contact HMIP-SWDO-I built-in solution Homematic IP Access Point
Homematic Window / Door Contact HM-Sec-SCo 130297 Gateway CCU2 as well as a valid CloudMatic subscription
Techno Line MA10800-1 Contact Sensor Gateway MA10001
In addition, most Zigbee and Z-Wave compatible opening sensors can be implemented within Conrad Connect projects using the Zipato integration.
