How to use the Delay Sensor
ChristianChristian Administrator, Moderator Posts: 2,035 admin
edited May 2019 in FAQs
The Delay Sensor is meant to delay certain actions within your Conrad Connect projects. Once the Delay Sensor is being triggered, a predefined time span in seconds needs to run down until the next element is being triggered. This comes in handy in many use cases. That's how it works:
Any questions or comments? Register for free and get started.
When creating a new Conrad Connect project, just grab the Delay Sensor from the left hand menu and drag it to the work space.
Let's take a use case from real life. We want a smart light to be turned on for exactely five minutes upon 'hitting' a Conrad Connect action button. That is, we connect the LED actuator directly to the trigger. The second line triggers the Delay Sensor first (set to 300 seconds), then it commands the same LED actuator to turn off the light again.
