These Smart Plugs work with Conrad Connect
ChristianChristian Administrator, Moderator Posts: 1,710 admin
edited July 29 in FAQs
If you would like to include conventional household devices to your Conrad Connect home automatisation projects, smart plugs are the key. We show, which smart outlets already work with Conrad Connect. Please note that no liability is assumed for the correctness of this information. Last update: July 29th, 2019.
Marke Gerät weitere Hardware -Voraussetzungen
Devolo Devolo Home Control Funk-Steckdose Devolo Hub ("Devolo Zentrale")
Devolo Home Control Funk-Steckdose 9354 Devolo Hub ("Devolo Zentrale")
egardia Funk-Steckdose egardia SPLUG-29 egardia Hub ("egardia Alarmzentrale")
Gigaset Gigaset Elements Plug S30851-H2519-R101 Gigaset Elements Gateway ("Gigaset Elements Hub Funk-Zentrale)"
Homematic IP HmIP-PDT Smart dimmer plug Homematic IP Access Point
Smart plug HMIP-PS Homematic Access Point
HMIP-PSM Smart plug with power meter Homematic IP Access Point
Homematic Homematic Smart plug 132989A0 1-Kanal 3680 W Control units CCU2 or CCU3 along with CloudMatic subscription
Smart plug with power meter HM-ES-PMSw1-Pl 130248 1-Kanal 3680 W Control units CCU2 or CCU3 along with CloudMatic subscription
innogy SmartHome Smart plug SmartHome Gateway "Funkzentrale"
Kopp Free Control Smart plug Free Control Funk-Zentrale
Free Control Smart plug with dimming option Free Control Funk-Zentrale
Osram OSRAM Smart+ Smart plug Zigbee-compatible Gateway, e.g. Philips Hue Bridge
OSRAM Smart+ Smart plug (Outdoor) Zigbee-compatible Gateway, e.g. Philips Hue Bridge
Smappee Comfort Plugs Smappee Monitor
Telldus most 433 MHz or Z-Wave based smart plugs Z-Wave Gateway TellStick ZNet Lite V2
TP-Link Casa TP-LINK HS100_EU WiFi Smart Plug 3680 W none, connected through WiFi
TP-Link Casa TP-LINK HS110_EU WiFi Smart Plug with power meter 3680 W none, connected through WiFi
Tuya Smart Plug with energy monitoring none, connected through WiFi
In addition, all Zigbee and Z-Wave compatible smart plugs can be controlled via Conrad Connect using the Zipato integration.
