Barometric sensors to Weatherhub cloud
bjehnbergbjehnberg Member Posts: 23
TFA Dostmann is about to introduce a barometric (i.e. air pressure) sensor with Weatherhub capabilities "Cosy Baro"
https://www.tfa-dostmann.de/en/produkt/digital-barometer-thermometer-hygrometer-cosy-baro/
(I'm sure MobileAlert and TechnoLine will do the same, but with different product names).
Will there be a ConradConnect widget for this sensor type as well?
Best regards/Björn
  • bjehnbergbjehnberg Member Posts: 23
    Thank you, Christian, that would be absolutely fine. This sensor, when available, fills in a gap in the Weatherhub architecture and makes it possible to set up a complete weather observation site. A weather station worthy of the name should, in my opinion, at least be able to deliver the parameters temperature, humidity and air pressure. Rainfall and wind are good add-ons, but the basic values that must be reported are the former ones.
    Best regards/Björn
