Why after linking IFTTT with Conrad Connect, I get HTTP 401 Unauthorized
Hello,
1. I followed the steps to connect IFTTT to Conrad Connect as explained here :
https://community.conradconnect.de/discussion/534/
  1. and created a similar project like here :
    https://community.conradconnect.de/discussion/539/conrad-connect-projekte-ueber-ifttt-starten
But the applet in IFTTT is triggered with a button instead on weekdays.
The Applet in IFTTT is simple: I press a button and then send the Webhooks request
https://dashboard.conradconnect.de/api/webhook/ifttt?key=(mykey)
  1. I created a simple project in ConradConnect to receive the IFTTT Webhooks request and send a simple Telegram message.
Unfortunately it didn't work.
I tried to find what is the reason. Here is what I made sure of :
1. Telegram connection is working fine. I created another project on ConradConnect to send a simple message, and it came
2. The Applet is running, because I checked on IFTTT and every time I press the button the applet runs and send the request to ConradConnect.
3. I tried calling the (https://dashboard.conradconnect.de/api/webhook/ifttt?key=(mykey)) directly and I got :
{"message":"HTTP 401 Unauthorized","statusCode":401}
  1. I tried to delete the Authorization on ConradConnect for IFTTT, and create a clean project there and repeat the steps
What could be reason for this message ?
What I have done wrong ?
how can I correct that ?
Thanks,
