IFTTT - Test project to test the connection between Conrad Connect and IFTTT
RAIKRAIK Member Posts: 3
You find here a test project for testing the IFTTT connection:
https://dashboard.conradconnect.de/projects/public/5e0910c8d172c6e2d1e8dbcb
Unfortunately the IFTTT project is not executed if the IFTTT Maker Channel is used. Is that a bug? If yes, the please feel to comment if you find the problem
The IFTTT project looks ok if it is executed by manual firing of the web request (e.g. by CURL command line tool). It also works if the IFTTT Maker channel is replaced by a Maker Tool but it seems to be not running if the IFTTT Maker Channel is used.
