Kann ich alle Homematic (ohne IP) Geräte via Cloudmatic und Conrad Connect nutzen?
OutOfMunichOutOfMunich Member Posts: 2
edited December 2018 in Hilfe beim Einstieg
Hallo zusammen!
Meine Homematic Installation umfasst 60 Geräte.
ConradConnect-Cloudmatic zeigt nur 36 an.
Wenn ich eine 3rd Party App (PocketControl HM) verwende sind alle 60 Geräte sichtbar.
Hat jemand ähnliche Erfahrungen und vielleicht eine Idee woran es liegen könnte?
Merci!
  • GiorgiGiorgi Member Posts: 25
    Vl weil nicht alle Geräte kompatibel sind? Hier ist die Liste die Conrad Connect im Help Center zeigt
    HM-Cen-O-TW-x-x-2 Central Control Unit CCU2
    HM-CC-RT-DN Wireless Radiator Thermostat
    HM-TC-IT-WM-W-EU Wireless Room Thermostat, surface mount
    HM-WDS10-TH-O Wireless Temperature/Humidity Sensor, outdoor
    HM-WDS40-TH-I-2 Wireless Temperature/Humidity Sensor, indoor
    HM-WDS30-T-O Wireless Temperature Sensor, outdoor
    HM-Sec-RHS Wireless Window Rotary Handle Sensor
    HM-Sec-SC-2 Wireless Shutter Contact
    HM-Sec-SCo Wireless Door/Window Sensor, optical
    HM-PB-4Dis-WM-2
    Flat wireless push-button with colour graphic display
    HM-SwI-3-FM Wireless Switch Interface 3 channels, flush-mount
    HM-LC-Dim1PWM-CV
    Wireless Dimming Actuator 1-channel, PWM LED, ceiling-void mount
    HM-SCI-3-FM
    Wireless Shutter Contact Interface 3-channel, flush-mount
    HM-LC-Dim1T-FM
    Wireless Dimming Actuator 1-channel, trailing edge, flush-mount
    HM-PBI-4-FM
    Wireless Push-Button Interface 4-channel, flush-mount
    HM-LC-Dim1T-CV
    Wireless Dimming Actuator 1-channel, trailing edge, ceiling-void mount
    HM-PB-2-WM55-2 Wireless Push-Button 2 channels, surface-mount
    HM-LC-Dim1L-CV
    Wireless Dimming Actuator 1-channel, leading edge, ceiling void mount
    HM-RC-2-PBU-FM
    Wireless Remote Control 2-channel for brand switch systems, flush-mount
    HM-LC-Dim2T-SM
    Wireless Dimming Actuator 2-channel, trailing edge, surface-mount
    HM-LC-Dim2L-SM
    Wireless Dimming Actuator 2-channel, leading edge, surface-mount
    HM-LC-Sw1-SM
    Wireless Switch Actuator 1-channel, surface-mount
    HM-LC-Sw4-SM
    Wireless Switch Actuator 4-channel, surface-mount
    HM-LC-Sw4-DR
    Wireless Switch Actuator 4-channel, DIN-rail mount
    HM-ES-PMSw1-Pl-DN-R1
    Wireless Switch Actuator 1-channel with power metering, plug adapter type F
    HM-PB-6-WM55 Wireless Push-Button 6 channels, surface-mount
    HM-LC-Sw1-FM Wireless Switch Actuator 1-channel, flush-mount
    HM-LC-Dim1TPBU-FM
    Wireless Dimming Actuator 1-channel for brand switch systems, trailing edge, flush-mount
    HM-LC-Sw1PBU-FM
    Wireless Switch Actuator 1-channel for brand switch systems, flush-mount
    HM-LC-Sw2-FM Wireless Switch Actuator 2-channel, flush-mount
    HM-LC-Sw4-WM Wireless Switch Actuator 4-channel, wall-mount
    HM-Dis-EP-WM55
    Wireless Status Display with push-button for 55 mm frames
    HM-LC-Sw1-DR
    Wireless Switch Actuator 1-channel, DIN rail mount
    HM-LC-Dim1T-DR
    Wireless Dimming Actuator 1-channel, DIN rail mount
    HM-LC-Sw1-Pl-DN-R1
    Wireless Switch Actuator 1-channel, plug adapter type F
    HM-LC-Bl1-SM
    Wireless Shutter Actuator 1-channel, surface-mount
    HM-LC-Bl1-FM Wireless Shutter Actuator 1-channel, flush-mount
    HM-LC-Bl1PBU-FM
    Wireless Shutter Actuator 1-channel for brand switch systems, flush-mount
    HM-Sec-SD-2 Wireless Smoke Alarm
    HM-Sen-MDIR-O-2 Wireless Motion Detector, outdoor
    HM-OU-LED16 Wireless Status Monitor LED16
    HM-Sec-Sir-WM Wireless Siren with signal light
    HM-Sen-EP Wireless Sensor for Electrical Pulses
    HM-Sec-WDS-2 Wireless Water Detection Sensor
    HM-Sec-SFA-SM Wireless Siren/Flash Actuator
    HM-Sec-MDIR-2 Wireless Motion Detector, indoor
    HM-RC-Sec4-3 Remote Control 4 buttons, alarm
    HM-OU-CFM-TW Wireless Combination Signalling Device MP3
    HM-Sec-TiS Wireless Tilt Sensor
    HM-RC-Key4-3 Remote Control 4 buttons KeyMatic
    HM-Sec-Key-S
    Wireless Door Lock Actuator KeyMatic, silver with remote control
    HM-Sec-Key
    Wireless Door Lock Actuator KeyMatic, white with remote control
    HM-Sec-Win Wireless Window Drive WinMatic
    HM-RC-4-3 Remote Control, 4 buttons
    HM-RC-12-W Remote Control 12 buttons, white
    HM-RC-12-B Remote Control 12 buttons, black
    HM-RC-19 Remote Control 19 buttons, white
    HM-RC-19-B Remote Control 19 buttons
    HM-RC-8 Remote Control 8 buttons
    HM-Sen-RD-O Wireless Rain Sensor
    HM-WDS100-C6-O-2 Wireless Weather Data Sensor
    HMW-LC-Sw2-DR
    Wired RS485 Switch Actuator 2-channel, DIN rail mount
    HMW-Sys-Tm-DR Wired RS485 Bus Terminator, DIN rail mount
    HMW-LC-Dim1L-DR
    Wired RS485 Dimming Actuator 1-channel, leading edge, DIN rail mount
    HMW-LC-Bl1-DR
    Wired RS485 Shutter Actuator 1-channel, DIN rail mount
    HMW-IO-12-Sw14-DR
    Wired RS485 I/O Module with 12 inputs, 14 outputs, DIN rail mount
    HMW-IO-12-Sw7-DR
    Wired RS485 I/O Module 12-channel in, 7-channel switch actuator, DIN rail mount
    HMW-Sen-SC-12-DR
    Wired RS485 Shutter Contact 12-channel, DIN rail mount
    HM-OU-CF-Pl Wireless door chime with light signal 1-channel
    HM-CC-SCD Wireless Carbon Dioxide Sensor
    HM-Sec-MDIR-3 Wireless Motion Detector, indoor
    HM-LC-Dim1T-Pl-3
    Wireless Dimming Actuator 1-channel, leading edge, plug adapter
    HM-LC-Dim1L-Pl-3
    Wireless Dimming Actuator 1-channel, trailing edge, plug adapter
    HM-LC-Sw1-Ba-PCB Wireless Switch Actuator, battery powered
  • OutOfMunichOutOfMunich Member Posts: 2
    Danke!
    Das scheint die Lösung zu sein.
    Blöd ist es trotzdem. Beispiele:
    • Bewegungsmelder innen HM-Sec-MDIR wird in der Version 2 (HM-Sec-MDIR-2) und 3 (HM-Sec-MDIR-3) unterstützt, jedoch nicht in der Version 1 (HM-Sec-MDIR)
    • Schaltaktoren / Zwischenstecker werden nur teilweise unterstützt HM-LC-Sw1-PI-2 und HM-LC-Sw1-PI nicht
    Ja, die Dinger sind schon ein paar Jahre alt, aber funktional hat sich da nichts geändert.
    Werde mal versuchen einen Service-Request zu öffnen.....
  • adrian_gengadrian_geng Member Posts: 1
    Komischerweise werden bei mir leider beide Steckdosenschalter "Homematic Funk-Schaltaktor HM-ES-PMSw1-Pl" nicht angezeigt... obwohl laut Liste ja kompatibel?
    Jemand die Dinger am Laufen via Conrad Connect?
  • ChristianChristian Administrator, Moderator Posts: 2,091 admin
    Hallo @adrian_geng, läuft es denn sonst prinzipiell bei dir?
