Trigger Conrad Connect with IFTTT
ndesilvandesilva Member Posts: 23
Hi Christian, I'm coming over from Stringify trying to get CC to do few simple things... hope I can get it to work.
I connected IFTTT using https://community.conradconnect.de/discussion/534/
I also connected my TP-Link lights to CC.
I have an Applet on IFTTT when my garage door opens to turn the lights to Red. What I want to CC to do is when the Garage door closes to turn the lights off if it's daytime, and turn them on to a different color if it's night.
Step 1 is to create a IFTTT Applet to trigger Webhook when garage is closed. What URL do I put in for the Make Web Request? For instance Step 4 on...
https://community.conradconnect.de/discussion/535/how-to-trigger-conrad-connect-projects-via-ifttt
Where do I get this link on Step 4... https://dashboard.conradconnect.de/api/webhook/ifttt?key=dAG-????
Thank you very much for your help!
-Nam
«1
  • ChristianChristian admin Administrator, Moderator Posts: 1,672 admin
    edited July 11
    Hi @ndesilva, welcome to Conrad Connect! So, your door sensor works with IFTTT, that is, you want two IFTTT applets to fire, one in case the door opens, one in case it's been closed. The THAT part of these applet shall be outgoing webhooks that trigger the desired projects in Conrad Connect, right?
    1) IFTTT must connected to Conrad Connect (is done, you said)
    2) The so called Webhook key is being provided by IFTTT, go here, then click on Documentation. Be careful not to change a once established key by accident.
    3) If the previous steps have been completed, the webhook URL is https://dashboard.conradconnect.de/api/webhook/ifttt?key=HERE_THE_VALID_WEBHOOK_KEY
    4) Use POST, application/jason and for the body: {"event":"garageopen"}
    5) create a second applet that is being triggered when the door closes with {"event":"garageclosed"}
    The event names are: garageopen and garageclosed. Now use the IFTTT Maker Channel Event Sensor in order to trigger your lamps with it as desired.
  • ndesilvandesilva Member Posts: 23
    Hi Christian, thank you so much for your quick response!
    So far so good. Next step is once IFTTT trigger event (when Garage door closes), which will trigger my project in CC through IFTTT Webhook (as I already completed) how do I use the Time Function in CC? I want if it's Day time to turn off my lights, or if it's night time then turn them on to a different color.
    See attached Screenshot how I have it configured so far...
    Thank you very much!
    Sorry, I changed it a bit. I figured I need 2 Timer Functions. 1 to trigger if it's Day time, and another to trigger if it's Night time. How do I tell 1st Timer Function to trigger if it's Day time, and 2nd to trigger if it's Night time.
    Thank you!
    Hi @ndesilva, please proceed as shown below. The IFTTT Maker Channel event sensor (which itself is being triggered when door closes) is to be combined as shown below. That is IF (Door = open) AND (Is Day? = Day) THEN turn off the lights.
    Then simply clon the setup in order to create a rule for the night. Both flows will fit into one project.
    Thanks Christian. I did exactly per your instructions. Seems like IFTTT is not triggering the Webhook. In the IFTTT Applet for the URL I have https://dashboard.conradconnect.de/api/webhook/ifttt?key=MY_WEBHOOK_KEY that I copied per your previous instructions.
    Rest is as per attached screenshot. Is this correct? Why is it not triggering my lights?
    Here's the CC Recipe I made per your instructions.
    Hi @ndesilva, just in case my instruction was misleading, the URL must include the exact key as provided by IFTTT. So if the key is kqjwefhqewufn845huf the URL is https://dashboard.conradconnect.de/api/webhook/ifttt?key=kqjwefhqewufn845huf. As a second validation step, please use a message actuator directly after the IFTTT Channel Maker Event. This way you'll see if the the sensor really does something. If yes, we know everything works until here.
    Hi Christian, yes I followed your instructions and copied the Webhook key from Documentation. And I added message actuators to the Recipe as per attached picture. No joy... :(
    What am I doing wrong? Thank you very much.
    I tried with Action Button in place of the IFTTT Channel Maker and the recipe works fine. Something is not right with the IFTTT.
    When I have the Action Button BEFORE the IFTTT recipe does NOT work. For sure something is not right with IFTTT in my recipe.
    edited July 13
    Hi @ndesilva, good to know that it works with the Action button, so we can focus on the IFTTT part. As next steps, please do this: 1) Set up a new IFTTT Applet as such: "IF Door Closes, send me a text message", so we know for sure, that the sensor works in combination with IFTTT. 2) Next, please check here to see if the connection between CC and IFTTT is still established. 3) Now please check your [webhook settings] once again, click on Documentation, then verify the entire URL incl. the key. 4) As a last step, please post a screenshot of your entire IFTTT applet here (please grey out the key). I'll have a loook at it.
    Hi @Christian, I followed your steps:
    1) I created new IFTTT trigger to turn off the lights and that worked. So we know that when the Garage door closes it does trigger IFTTT correctly.
    2) Followed your link and refreshed the IFTTT connection in CC.
    3) I copied and pasted only the Key into the URL you provided earlier. See attached screenshot of the Applet.
    4) Attached. Bottom part of the IFTTT Applet is on my previous message. Sorry I can't get them all on one shot.
    edited July 14
    Hi @ndesilva, looks all good until here. Also, re-examing this part, all is fine (just verify that there are no unwanted space characters)
    Let me therefore now look at the IFTTT Maker Channel Event sensor:
    The setup looks right to me (again, please verify that there are no unwanted space characters).
    Is the subsequent actuator (or logical gate) set in a way that it listens to event?
    Let's please focus on getting a message actuator triggered for now, so this is our next step.
    PS: You should activate the mode where IFTTT sends you a push message each time the applet runs.
    Hi @Christian I verified there are no spaces. I copied what you had before and pasted. One thing I noticed was that when I tried with the Action Button it worked, but only when I had No Event selected in the And gate. It did not work when I had Event selected.
    For some reason in IFTTT this Applet keep turning off the push message option. All my other Applets have that turned on and is working. But when I created Applet to turn off lights when Garage Closed it did work and sent me a message. Just not with Webhook it keeps turning it off after I Save it. Not sure why.
    edited July 14
    For instance I get notification with this Applet when the Garage Closes.
    Hi @ndesilva, let's please neglect the project with the AND gate. Let's focus on getting a message actuator triggered by the IFTTT Maker Channel Event sensor. I have published a similar project here. If you have Pushover, which I recommend, you may import it directly so as to study it. Otherwise I'll post you screenshots.
    Hi @Christian I don't have Pushover. So I removed it and added Mail. I did one with your Recipe and also created a new one with Action Button. Neither one worked. Seems like my IFTTT in CC is not working. So I went to Devices. Revoked access and delete data on IFTTT in CC. Re-established access. Re-did the Recipes using yours and created new one. Still not working... :(
    Hi @ndesilva, I will try to cover this in a detailed tutorial. What is the brand of your sensors? Thanks.
    Hi @Christian I have Garadget for the Garage door and TP-Link lights.
    Why isn't my IFTTT getting triggered in CC?
    Hi @Christian so I was testing with few things and I got it to work! For the trigger I have both Event and No Event from IFTTT in my recipe. When I have Event only it doesn't work.
    Now I'm going to try with AND gate. I'll let you know what happens.
    Thank you for your help!
    Hi @ndesilva, great to hear. However, what you describe shouldn't be the case. Because only "event" is desired triggering signal. Let's see how you progress and then get in touch once more here.
    Hi @Christian I've been testing it and so far it's working great. I have 2 separate recipes even though I could probably incorporate them into one.
    Is there a function where I can say if the garage door is open 1 hour before Sunset then... ? I can't really use "Is Between Hours" gate since Sun set at different times during the year. I have the lights to come on about an hour before Sunset and currently if the garage is opened before Sunset it turns off the lights and I have to manually turn them on.
    Hi @ndesilva, yes, as part of the free plan, you may use up to eight actuators and/or sensors within one project, even if they constitute independent routines. You are right, the said project can neither be solved with the Between Hours nor Is Day? sensor. In such cases, I usually recommend Switchur because it allows storing and processing variables. If you are patient enough, start creating a Switchur Switch variable that represents the status of the door, then we'll talk about the final part. This is a bit more sophisticated though.
    Hi @Christian great. I have options. I will give Switchur a try and let you know. Thank you very much!
    Hi @Christian I registered at Switchur. How do I connect Switchur to CC? It is not available at:
    https://dashboard.conradconnect.de/devices
    edited July 26
    Hi @ndesilva, Switchur is not a service you can connect. The connection between both worlds is made through HTTP POST requests (aka webhooks). That is, you 1) create an Switchur account, 2) define the varible within Switchur, 3) create a project in CC with Conrad Maker acuators which set the variables, 4) create an automation within Switchur (= processing of the variable) which in returns uses HTTP requests in order to trigger the desired action in Conrad Connect. For this, please use the IFTTT Maker Channel Event sensor which itself then triggers the desired actuator.
    Hi @Christian I did step 1 create an Switchur account, 2) define the varible within Switchur.
    For Step 3... I'm following this:
    https://community.conradconnect.de/discussion/577/how-to-store-sensor-readings-as-variables-in-switchur
    Here I'm stuck at step 6. Where you have Kontakt_1_windowState_1 and conradMaker_1.
    I don't see a way to make Kontakt_1_windowState_1 ?
    edited July 28
    Hi @ndesilva, let me try to hint at some details here. "Kontakt 1" is the name I've assigned to the hardware sensor when setting it up a year ago. Kontakt_1_windowState_1 is the name of the same sensor within the Conrad Connect editor, that is, you can grab it and place it as a sensor to the canvas of project editor . The Conrad Maker is an actuator that can make HTTP requests. So this has to be configured in a way that the HTTP request actually triggers the variable within Switchur. If you create a variable within Switchur, the required URLs to set up the Conrad Maker actuator is already being provided, please look here:
    And here the remaining details for the Conrad Maker:
